Which brand/style rims for my car?
Groundation
90
Jul 1, 2008
Hilo, Hawaii
Hi all
My 1990 Talon Tsi is in bad need of new tires. Instead of getting tires for my stock rims, I want to get some new rims now so I don't have to buy tires again when I upgrade.
From my research on this site, I have decided that I want a 17" x 8" rim with around a 38mm or so offset. I plan to run a 235 x 45 or 235 x 40 tires on them.
I have never bought rims before or payed much attention to what is a good wheel. I have heard of the mainstream brands like enkei, rota, etc. but I have no idea which are better or look good on a 1ga.
My main criteria for the wheels are lightweight, Non-flashy (no chrome etc.) and 17" x 8" with around 38mm offset, good quality, and look good (clean) on a 1ga.
My budget is around $1000 or so, less is always better.
I look forward to hearing suggestions or comments.
Thanks
the $1k or so is the budget just for the rims.
My cars color is black cherry, I believe its called. I have seen a few cars with the same color as mine with bronze rims, and I think it looks pretty good.
I got 17x8s on my DD Malibu. I recommend going 245/45 if you can fit without rubbing. The 245 fills the rim up pretty good and would help prevent some curb rash.
I would definitely go with wider tires if I could, but 245's might rub without any fender work, which I don't really want to do at this time. So maybe I should be looking at a 7.5" wide rim then.
I'm just trying to get the widest tires I can fit with stock fenders. From what I have read on these forums, some people have used 245s on stock fenders, but it is not guaranteed to fit without rubbing.
If it matters for fitment for the rims, I have koni yellows w/ground control coilovers for my suspension. I just have to install them.
I picked up a set of Enkei SC03's not too long ago for $996.00 with tires mounted and balanced, centering rings, locks, etc. They're a little over 20lbs for the 17" X 7". I got mine at wheelsnext.com, which I don't really recommend using. Took forever for the rims to get to me and every time I called to find out what was going on they told me about a problem with this piece or that piece that was delaying the order. Never would have let me know if I didn't pester them once a week. Just search around, tire and wheel deals are always popping up out there.
Rota Slipstreams look real nice on 1Gs. Not too flashy, but have a subtle, racey sort of look. If you look through the galleries you can probably find a few nice pictures of them, they seem to be very common on some serious drag builds.
A lot of guys also find rims of Evo 8s, I think the six-spoke rims are by Enkei, and they look real good on 1Gs as well, and they might even already be in the 17" size you are looking for.
I would definitely not go with Rota Slipstreams, Slips are more directed for Hondas, I would go with Rota D2's.
Hey thanks for the suggestions
I do like the rota slipstreams, that is a nice choice. The d2's are also nice, they are similar but seem a little more flashy to me with the rivets and all. I like them both though.
Why are slipstreams more directed to hondas? From google searching they seem to be pretty popular with the honda crowd, is it just that a lot of hondas use them? Or is there something else that makes them honda rims. A lot of dsm's seem to run them too.
The evo8 rims look good too and seem to match exactly what I want: 17" x 8" and a lot of people seem to be running 235 45s on them too with no fitment issues.
Evo8 rims 20.5 lbs. , ROTA D2 17 x 7.5" 22.5lbs. , ROTA Slipstreams 17 x 8 20.2 lbs.
So they are all similar in weight.
Thanks again for the suggestions
Those Volk ce28n's look really nice and are very light, unfortunately they are a little expensive. I'm seeing prices of $700 or so each rim which is more than I want to spend.
The KDW's are one of the tires I'm considering, I need something that has good wet traction.
Thanks for the suggestion
  • Wanted 6 bolt NT water pipe
    • chrisman287
