Where to get silicone coolant/oil hoses?
leakyfaucet
818
May 29, 2004
cincinnati, Vermont
The oil and coolant hoses running to my turbo are looking pretty bad, I was wondering if anyone made some silicone hoses about the same size. Also, I'll probably be replacing my heater hoses and a bunch of vacuum lines. Anyone know a good place to get silicone hoses for these purposes?
Thanks!
Thanks for the link. They have a good selection of vacuum hoses, but it doesn't say anything about coolant or oil lines. I guess oil lines shouldn't be made of silicone, I think it might eat it away or something.
Anyone know where to get stock replacement heater hoses?
Try the mitsu dealership for the OEM heater hose. As for the oil lines do you mean like the oil feed and return lines to the turbo?And which coolant hoses are you replacing?All of them?
Some of the lines that run to the turbo are metal with small sections of rubber hose. I haven't looked close enough to see if they are oil or coolant but I think they might be both. Those and the heater hoses are what I'm most interested in replacing, as they are starting to get soft and sticky.
I'll try the dealer, but they're probably asking like $50 a hose or some crap like that.
for the entire hose setup in the 4g63t, the mitsu dealer here in utah wanted 170 bucks. that was not including vaccuum hoses. i just called them like 2 days ago.
  • Wanted 6 bolt NT water pipe
    • chrisman287
