1G Where to find OEM mudflaps?
HokieDSM
1,725
Oct 24, 2002
Blacksburg, Virginia
I'm looking for a set of the OEM 1Gb mudflaps . They usually say "Talon" on them - I've seen them, so I know they exist.
Does anywhere know where I might be able to find them? I really don't care if they say Talon or not - just looking for a set of OE flaps - last I checked, Conicelli didn't have them.
Here are the OEM part numbers:
1G 2.0 Turbo AWD M/T:
Left Mudflap = MB597761
Right Mudflap = MB597762
Upper Fastener = MS240156 (You'll need 2)
Lower Clip = MB406894 (You'll need 2)
I pulled these from CAPS for a GSX. I would assume they are similiar if not the same as what's on your Talon. Start calling Mitsu dealers and give them those part numbers.
Sorry...you are right. I pulled the wrong part numbers, my bad. I edited the above post though and the part numbers there are correct.
-James
any luck finding the mudflaps? im looking for a set myself execpt for a 1ga. im wondering if they are the same as the 1gb. i have only seen an imcomplete set at the junkyard once
Somebody with a set really should look into taking dimensions and putting them up. For the brackets and the flaps.. Front and rear. That way we can just make them. To be honest I couldn't even find them in the parts program.
I am going to be a gravedigger and bring this back.
I just got a set of mudflaps from the JY. Came off of a 1gb and say ECLIPSE on them. I think they are pretty rare, I've never seen them before. Got them for a steal too....$2.50 each at the JY.
  • Wanted 6 bolt NT water pipe
    • chrisman287
