Where to buy motor mounts?
Cheks_Talon_TSi
228
3
Oct 24, 2003
Monterrey, N.L., Central America
Can someone tell me where to buy all motor/transmission mounts for my 1G DSM Turbo FWD / 5 speed manual trany car????
I also notice that my car has 4 mounts. The frontal and rear motor mount, the transmission mount and one more in front of the trany mount, how does that mount is called? or how does I ask for it???
I will apreciate a lot any help... and if anyone has the part numbers for those items will be even better...
Thanks in advance...
Sergio G. :talon: :thumb:
energy suspensions, check them out and see if they have any local distributor in your area... or online store distributor will do too..
I got the prothane from RoadRaceEngineering, for a 2G the timing belt and tranny mount are a complete replace (burn /cut the old and press the prothane in), and the front and rear are inserts. On a 1G I belive the prothane have 3 complete replacements and 1 insert.
I just installed a set of energy suspensions on a friends GSR. I REALLY like the Prothanes more. the E/S are are alot softer and are inserts only, then to hold hte inserts in there is a zip tie style lock. go with the prothane your car will vibrate ALOT more but it will loosen up in a week or two (but will still vibrate)
Thanks everybody for your advices. I made my research job and what I conclude is that lightningmotorsports.com is the one that have a better price on the web ($67.62). The part number they give to 1G DSM Prothane Mounts is 13-1902 for the complete engine mounts (insert kit). Those this is the one that has 3 for complete replacement and 1 for insert??? or the 4 mounts are for insert??? anybody knows???
Thanks once again!
Does anyone know what the part number is for the driver's side motor mount insert (OEM, not Prothane.) I tried to order one from the dealer, but they gave me the rubber stopper instead :(. So if anyone could, it would be a great help to let them know which part it is instead of having them search for another 10 minutes.
Thanks once again!
I dunno the part number but the prothane kit for the 1g is 3 complete replacements (back/left/right) and only the front has the insert
I think that there are 2 types of Prothane Kits:
A) Full Motor Mount replacement kit: Back, left and right for replacement and only the front as insert. Part number ???????; and
B) Motor Mount Insert Kit: The four pieces are for insert. Part Number 13-1902
As far as i have search, the "A" option is saled by: V-Match and Road Race Engineer. The "B" option is offered by summit, nopi and lighting motorsports. Obviously the B-option is cheaper.
Well, this is what I can understood from my research but I'am not sure of this. Maybe there is only one option of kit. :shhh: :shhh: :shhh: OMG If anyone can confirm this, will be excelent!!! ;) :thumb:
  • Wanted 6 bolt NT water pipe
    • chrisman287
