Where can i get my car plugged in
justinmolnar
Feb 27, 2005
Seville, Ohio
I have a 95 GST. The turbo went at about 100,000 miles so i replaced it with a big 16 G turbo and ever since then the check engine light is on and my car is runny really rich, What are some suggestions?? I would like to get it plugged in but i cant find anywhere to do it. I tried autozone and they said it has to be a 96 or up where should i go??? :dsm:
Dont know where to tell you to go get it checked, but I will say if you going to do upgrades like that. You are going to need a logger of some sort. Cant mod a car and expect it to run right, and last if you cant monitor it.. ;)
Wendy
just head on back to autozone and tell them it is a 96.......the 95 and up gst's and gsx's are obdii compliant (more or less...) and they can pull the codes with the obdii scanner. IF the guy is smart enough to remember you or look at the door pillar and say it don't work on pre 96's just point him to your obdii plug underneath the dash between steering wheel and the center console and ask him to try anyway.
BTW listen to Wendy, you'll most likely need more than the obdii trouble codes to fix your now modded car.
