Where can I buy an air tank?
vr4gasmtt
203
Feb 15, 2006
In, Oregon
Whats the cheapest place I can get an air tank to run a boost leak test? I searched, some people said go to Walmart, but Walmart is 200 miles from where I live.
Where should I go, and what exactly am I asking for?
I've seen Home Depot offer a great price (just over $100) for a pancake-style compressor with a couple tools. Could also check out Harbor Freight, Sears, eBay or the local Farmers Market / Swapper Rag... keyword "Air Compressor" :dsm:
Most of the big chain auto parts stores have chinese built compressors that compete in price with good ole' Harbor Freight. You can look there first. Otherwise you can get one of these for $60.
or one of these for $24 at HF.
I didn't know you could still get 200 miles from a Wal*Mart. You're probably best off going to eBay, or just using a bicycle pump. You're not dealing with a lot of volume, nor a lot of pressure.
Even then, those tiny compressors wouldn't even be enough to run an air ratchet, much less an impact gun. Bike pump, or one of those cheapo emergency tire inflators that plug into your cigarette lighter. They should be able to handle 20psi no problem, and a lot of them come with an auto-shutoff dial so it won't over-pressurize the intake tract.
Exactly, unless youre planning on running some air tools, just use a $5 bike pump.
Well from searching alot of boost leak threads, most of the people are saying that a bike pump won't be able to pressurize the system fast enough, before all the leaks get out. But I guess I will go out and buy a bike pump and see how that works.
I'm hoping I have a boost leak, otherwise, its either the motor or the turbo.
A bike pump? That's really not going to work. Tire air compressor doesn't work well either. It's too loud when it's on.
If you have a boost leak how are you going to find it with a bike pump? You'll just be pumping all day and build no pressure. A tire air compressor is way too slow as well. It shoots out little puffs of air. Now it will build pressure if there are no leaks, but what if there are? The thing is way too loud when it's on to hear the leaks.
Air tank is cheaper than air compressor. You can fill air tanks at a gas station but you'll just have to go back to refill
Where should I be looking for an air tank then? I could not find no HF air tank for $24, any one have a link?
Actually both methods have worked fine for me.
With a bike pump, unless you have a massive boost leak it is not going to all escape before you can hear it. I guess if you have a massive boost leak this might happen, but that's when you get a friend to pump while you check for leaks.
And a tire air compressor works also, you just can't be right next to the compressor LOL. If it has a long hose and you're far enough away from it with some soapy water you can definately find boost leaks.
    • george bromwell
    • pma1123
    • Sdcryan1
