what size injectors please
EclipseTrbo420A
3,427
39
Jan 23, 2004
WhiteOak/PGH, Pennsylvania
mods are 97 GSX
1st Gen BOV , 3 Inch Custom Turbo Back ,FMIC, airfilter w/hacked recirc tube,MBC set @ 14 Lbs, WalBro 255 ,S-AFC (Blue Screen) Auto Meter Boost , Air Fuel and Oil Press Gauges. DATA Logger , Carbon Fiber Hood , RMDSM Lip
balance shaft eliminator kit , bore .020 ,Howell Stock rebuil Kit...Pistons , Rods , Crank ,
KYB GR-2 Struts , ACE 17 inch Hyper Black rims , RMDSM LIP , Carbon Fiber Hood
Big 16G and a 2.5 inch J pipe On the way , now all i need is clutch and injectors and im set
ohh and
i am ordering injectors and i want to know what would be best for a daily driver i want to run about 20 lbs or so .... thanks in advance guys :dsm:
550s should be fine if your sticking to the 16g, if you think youll upgrade then go for bigger.
Andrew
I would say get the 550's too but then I noticed you had the RMDSM lip. Now I think you might need the 650's.
Actually he has two of them, as well as two carbon fiber hoods. Better make it 660s... just to be safe.
:p
Thanks guys 550's it is and yeah well i didnt know what "mod list" to put the lip and hoodS under :p and 92awddsm thanks bro ;)
*edit* the first post was just a copy and paste from another thread in it , that why there all the usless info there LOL :D
