what should i do next to my car. engine wise
jizordan
32
Feb 22, 2004
lake havasu, Arizona
RSR Downpipe, APEX FMIC and piping, Steel Braided Hoses, Greddy 18G Turbo Upgrade, Weapon R V2 Hyper Filter, Greddy Exhaust, SARD blowoff valve, nology Wires, NGK Spark plugs, Randon Tech Cat, Clutch master stage 3, Greddy oil cooler, Weapn R Super Matrix Breather Filter, Weapon R Ultra fuel controller, Greddy Manual Boost Controller, HKS Fuel pump, Powder Coat Engine valve cover/engine parts (Red/Chrome), Optima battery. those are all ofthe mods
you have the most expensive mod list ever, LOL.
i suggest you tackle the fuel setup.
yeah i would say like everyone else some BIG injectors and a good ignition system too would be good with that and if u wanted u could get a cryo intercooler sprayer too LOL
ok i was already thinking about injectors. i was looking at denso injecotrs are these really any beter than the links you posted,and the fule system. what exactly should i do to it. and the mods i was actually looking or are what wold give me more performnace. right now i think i am running around 12lbs of boost. anyways does anyone have a slight idea how much hp i am putting out. thanks
You have a boost controller without a boost guage.
No more modding for you. Give me your car.
big injectors arent needed. 550's will be more than perfect. we dont want to add anymore overkill to his mod list.
hes very far away from needing an aftermarket ignition system.
I disagree with getting 550's. An 18G turbo is efficient and can easily handle 22 or so psi. Unless you're going to always run under 20 lbs of boost, then yes get the 550's. On my 16G at 21psi, I see injector duty cycles between 64 and 76 percent. This is a good range as I'll never max out these injectors. Up until the time when I run a 50trim on the car :D
ok so the most important mods right now are just a boost control gauge. so are you guys saying that if i run more boost i wont need any bigger injectos. sorri dont know that much about this car. i bought it from my neighbor right after he built it because he neede money. anyways what about like an safc. do you guys think i ned one. also vlarr do you have aim or yahoo. mine are under my name if you do will you talk to me. also anyone else who will talk to me over yahoo or aim please do. thanks
There's a lot to learn. Sounds like me when I was starting out:) I'm still learning though. Anyway, my AIM is FORCEFED2LTSI Drop me a line. Later.
Kevin
  • Wanted 6 bolt NT water pipe
    • chrisman287
