What machining is necessary for stroker
bsbllfit7
1,104
3
Feb 17, 2009
Salem, Oregon
I tried searching for the information and if anyone can post a link and make this simple that would be great, im wondering what all machining needs to be done to the block to accommodate a 2.3l stroker, I know the obvious honing boring if needed, and that you need 2.4l crank with stock length rods and stroker pistons, but what about oil squirters and that stuff (are they in there, do they need to be modified, do they need to be added) Im buying a spare block and starting a 2.3l build and want to know in advance what i might run into.
Just buy a stroker kit. its all in the crank, rods, and piston heads that deals with the length of the stroke.
well i know that but there is no work with the oil squirters that needs to be done? I remember reading about it somewhere or hearing it from someone, it could have been about making a 2.4l but im not sure. just wanting to make sure cause if not im gonna make the 2.3 liter myself
