what kind of translator for 2g eclipse?
vinh766
137
May 20, 2003
SoCal - ATL - PHX, California
i have a 95 gst and i was wondering what kind of translator can i use? 3s, ls1, ls6, impalla SS or can i only use one specifically for a 2g dsm. thanks
The translator comes in 1 version.. It filters the GM signal to be readable by the Mitsubishi ECU... You are talking about MAF differences... LS6 uses a 3.5" MAF, the rest that you described use the 3" MAF.. If you go with a 3" or a 3.5", they will both work with the DSM Translator...
so ur saying i can use a translator that was used on a ls1, ls6 or 1g eclipse just fine? as long as i get the 3inch maf appropiate for my 2g, correct?
well that's my question, can i get a translator from a different car (ex. 1g or ls1) to somehow work on my 2g?
You don't get it, there is no such thing as a Translator for an LS1 becuase the MAF from the LS1 is meant to be used in it... What translating is needed? As for using a 1G translator, I don't think there is any difference because the MAS wiring for the 1G and 2G are pretty much the same with the exception of the harness shape...
the translator is a device that converts the signal from GM MAS such as the LS1, LS6 or whichever MAF you want to a signal that the stock ecu can "understand" the translator and the maf are 2 separate things...and no you can't use a 1g translator in a 2g...plugs are diferent...If I were you I'll let the engine as stock as posible...you may end up blowing it OMG
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
  • Wanted Driver Side Front Side Skirt End for 97-99
    Looking for the driver side skirt end molding. Bonus if it has the mud/rock guard.
    • ProjectDSM
  • For sale 1997 Eagle talon esi
    runs and drives located in Oklahoma City
    • Nii
  • For sale 2 bare 7 bolt motors
    bare 7 bolt bottom ends
    • Nii
