what does the smoke mean?
c_k06
132
Mar 10, 2009
clarksville, Indiana
ok so i finally reassembled the whole engine from a new redone head and started it up. smoke came out of the exhaust and some out of the oil cap when i took it off and some even out of the air filter from the turbo. i did not get new rings and the guy i bought it from said that the rings could be a possibility. it ra like crap and i had to tap the gas the whole time to keep it running. also i heard a clicking noise like there was a rod knocking. what could it possibly be?????????:cry:
i took the head to a shop and they said that the valves were bent so they redid the head. then i started the reassembly of the whole thing. in my haste i did not pay attention to the pistons or block very much. the guy i bought it from is giving me an extra short block so my plans are to build that short block and drop it in and it should be fine.
ditto bigal -- if it's white it's coolant (or steam). Sounds like you didnt prep the head/block surface properly. How did you prep btw?
