What Can Be Swapped
Mikey851
88
5
Aug 5, 2014
Lubbock, Texas
Does anybody know what all can be swapped between a 1ga and 1gb as far as the body goes? For instance would the front end body panels and headlights of a 1ga Talon bolt on to a 1gb Eclipse? I have a 1990 Talon and a 94 Eclipse. I want to take the best parts from the Talon and bolt them onto the Eclipse before paint....including doors.
I'm not 100 percent sure but I believe the radiator support is different between the 1ga and 1gb, which wouldn't make for a direct swap, but I'm not to into 1gs so I may be wrong
I'll check later. That's actually a part that I hope swaps. If not it's a part that I would be fine welding into place.
