What are the benefits of a saturn alternator swap?
Captain D
51
Feb 18, 2007
Monument, Colorado
My alternator is failing and I have the option of getting a rebuilt stock alternator (92 GSX) that is 65 amps or do a Saturn alternator swap that can provide 130 amps after modifying. My question is what benefits do I get from an extra 65 amps?
I was looking at better engine performance. I have a walbro 255 fuel pump, will it be more efficient with less strain on the alternator? Will the fuel injections be more efficient?
Yes, it wouldn't hurt to have a stronger alternator anyway.
If you run a 130 amp alternator, you're going to want to upgrade the wiring from the alternator to the fuse box. And possibly the 100A fuse that's in the box.
Someone wrote a thread about using 4 gauge wire which sounds like a good idea to me. I've been doing a lot of research on the Saturn swap but the problem is that the information is spread out through numerous threads. It is difficult to get the complete picture. What amp fuse do you recommend?
Do they make 150A? Your 100A will probably hold up unless you have a whole bunch of electronics in the car and there's a large draw on the alternator. I'd want to make sure all the main power cables were in good shape before I'd step up a size on the fuse.
No need to change the fuse, leave it be.
The Saturn alt puts out more volts at idle when rewired then a typical DSM alt. Plus it's cheaper and has a better regulator then the DSM.
From what I've been told Canadian DSMs had 130amp alts from the factory because of DRLs, dunno how true that is.
  • For sale 2g 2G Driver Side & Manual Trans Mount with Poly Inserts
    2G Driver Side & Manual Trans Mount with Poly Inserts $70 + shipping & paypal feesYou must be...
  • For sale 2g 2G Dejon Tool Upper IC Pipes
    2G Dejon Tool Upper IC Pipes $80 + shipping & paypal fees* throttle body flange looks brand...
  • For sale 4G63 Cometic 86mm Head Gasket
    Cometic 86mm Head Gasket $70 + shipping & paypal fees.051 MLSYou must be registered to see...
  • Wanted 1g Looking for 1g interior
    Wanting to buy driver side a pillar interior (with pods preferred), both interior b pillars...
    • Walnuts
  • For sale 4G63 Ebay T3/T4 TO4E Turbo & Manifold
    Ebay T3/T4 TO4E Turbo & Manifold $100 + shipping & paypal feesYou must be registered to see...
