weird TPS reading and limp mode
brandonf90
100
4
Oct 11, 2012
davenport, Iowa
so i was testing my tps to see if its good (tranny limp mode) anyways i tested it via haynes manual, i set the closed resistance to .9 (then tightened it) but when i set the throttle body all the way open i was getting 4.2-4.3k resistance. i know its supposed to be 5k but would that contribute to my tranny going into limp mode? also when i would be setting the tps id get it set to just around .9 but i barely tap it and it will jump to 1.7k or so. what im asking is this telltale signs of a bad TPS ?
Your tcu is probably bad causing limp mode. Another thing with the tps, a bad tcu can screw with your tps readings. The tps circuit somehow runs through the tcu and if it's bad can make the tps act like a bad one. It happened to me once and I replaced 2 tps sensors before I figured out it was the tcu.
Wait a second! The ecu and tcu do not communicate. The tcu gets all its information from the tps, the vss (speedo), tach, and throttle position switch (on/of switch on the throttle body closest to the firewall. .green wire)
I would pull the tcu plug and set the tps. It's tied into the ecu and the tcu. Then report back.
i test my TPS with the throttle body removed and not plugged into the car. im just reading direct resistance from the TPS prongs.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
