echostats
- 158
- 0
- Dec 7, 2004
Massillon,
Ohio
I guess I am an idiot. I take that back, I am an idiot. Sunday (2 days ago) I was washing my car and decided to pop the hood for a quick second and give it a spray. Yes, just so you don't have to ask, this is a power washer... I didn't give it any power but still WTF was I thinking?!
The car started fine but when I got to the road I knew I had messed something up. I got it home and it was idling TERRIBLE, shaking, sputtering... It has never sounded worse or anything like this. I shut the piece off and checked to see if I had knocked anything loose or anything noticable.
I got some towels and dabbed up some water, yes, water, that was sitting on my valve cover. When it was dry enough I pulled the wires, dried the wires, etc. I started it up after letting it sit for an hour or so and was running fine. I decided to run it down the road to see what would happen. About the time I get out of my driveway, the CEL comes on and the engine would bog. Bog to the point where I could barely make it up this hill to get home. When I say barely... I mean I was seconds away from giving up and backing down the hill. It was just NOT going anywhere. It has no power and sucked balls.
I got it home, again and took it to the barn to spray it with an air compressor to get any excess water off. I sprayed the coil pack, the wire/coil connectors, inside the cylinders, everything I could think of. I cleared the CEL and I let it sit for another hour and then drove it. RAN PERFECT! Just as good as always! BUT! The RPM on the tach would not read and the SAFC would not read the RPMs either. The AFC would read the throttle MOST of the time but then I wasn't real sure if it was right. This whole time, the car was running perfect, so I thought. I finally got worried enough to bring it back home.
Tonight I took it out, seemed to be PERFECT again. AFC was reading the RPM but the tach still wouldn't. I get a little ways down the main road when it start to bog at about WOT and at the same time the I get a CEL. I let off and pull it into a lot for whatever reason. At this point I have no idea what to do, I drive it home and it's in the garage until I can get some ideas from you guys for things to check.
My personal opinion is that it could be the MAS but I am no genius. I need some of you guys opinions. What should I check?
I give you permission to flame me for spraying my engine with a power washer. Dumbest thing I've ever done.
(sorry for the long post, hope none of the wisemen fell asleep reading it before they could help me fix my problem
. Anyhow, I ran the engine several times since then, wouldn't the water have dried up by now? boiled up probably and evaporated...?
