vpc problem
dsmcurse
968
14
Aug 14, 2009
Pasco, Washington
car wont start on vpc at all. as far as i can tell i have everything hooked up right. intake air temp sensor is mounted in the top on my upper intercooler pipe and its hooked up. the map sensor has its own direct vacume source right off the plenum. the sensor is on about 4-5"s of 3/16 hose and mounted above the intake manni. the harness that hooks up these two sensors are pluged into the vpc controller in the car. then the harness that goes into the ecu is also pluged into the vpc controller. the chip inside the vpc is a 450cc chip "dsm stock" my car is 780cc injectors but my chip in the EProm ecu is dsmlink V2.5 780cc injector. my ecu thinks the 780s are stock. so the 450 chip in the vpc should still think stock too right? i should also mention that i have a afc already wired into the cars harness. when i plug the vpc harness into the ecu and disconnect my mass air flow sensor plug-in and try to start the car it wont start at all. it trys to kinda but its so crappy. no matter how i adjust any of the knobs it doesnt really matter. car wont run. any sugestions?
