very high knock
overboostedtsi
47
Jun 12, 2002
Yakima, Washington
I did a 3rd gear pull tonight and my log looks horrible. My mods are in my profile.
RPM Knock Timing Throttle O2
2843 0 24 40 .82
2937 4 20 42 .82
3343 15 16 70 .90
3750 13 16 100 .92
4125 12 16 100 .92
4593 15 11 100 .94
5000 21 10 100 .92
5312 43 4 100 .88
5543 43 7 100 .86
Why am i knocking so much? I am only running 9 lbs of boost right now also. Any help would really be appreciated.
What are you intake temps. Also, .82, .84 and .86 might be a little on the lean side. If you have control over your timing I would pull back your timing as well.
idk about that being on the lean side, idk if my o2 sensor is dying, but i have my car running almost perfect right now, and see 2 counts of knock at 6k rpm w/ an o2 voltage of .84-.82, if i tune it to run "richer" meaning .89-.91, it hits fuel cut...so idk. What gas you usin?
Going off narrowband o2 voltage is worthless, gives you a vague idea about what is going on. ECU doesn't even acknowledge its existence at WOT anyway.
What plugs are you using? You better be saying NGK-BPR7ES
What are your high fuel trims? If they're at 140% I hope you're adding fuel on that AFC of yours
Whats your base timing set at?
