Venom 400 PCM on a 2G N/T Qs
smokir13
Aug 6, 2004
fayetteville, North Carolina
I recently bought and installed a venom 400 pcm on my 1997 RS and I cant feel much difference. Advertised i should have gotten 25% more power blah blah blah which on a stock RS would be around 35 hp which would be verry noticable. NOW let me say a few things and then hopefully somebody can help me get my 25%. 1st its installed right. one wire to the map sensor, one to the TPS sensor then power and ground. Cant mess that up. 2nd I have a CAI with stock exhaust (just throwing that in there). And last I have an occasional Check engine light problem, codes as bad O2 sensor. Dont have the code :( I havent gotten a chance to take it to the track and run it for times to see if there is a difference, but i just wanted to know if others had a similar dilema and if there was something they did to make it better :dsm:
obviously you did no reasearch on the unit niether on this site nor 2gnt.....everyone would have advised AGAINST the venom module.....................
Did you see any gains (not on the butt dyno)? extremly doubful
Have you noticed loss in gas mileage? No,......you will......
How much did it cost you?
It's a waste. I was probably 1 of the 1st people to get ripped off when it was hyped up and all. The hype was for absolutely nothing. Get your money back. You probably can't sell it to anyone now. I sold mine, but this was back when they 1st came out. Everyone wanted it then.
