oldman
DSM Wiseman
- 9,788
- 196
- Jun 21, 2003
Dayton,
New Jersey
Does anyone have links to tach articles on changing the valve seals with the head attached?
I had excessive crank case pressure which blew my turbo seal. After I remove the exhuast manifold I can clearly see wet oil in and around the center two exhaust ports. Compession test was 165 162 155 160 dry and + 20 across wet. I will do another compression test tomorrow but it would have to be a cold test, most of intake and exhaust have been removed. Do you guys agree that I probably blew valve seals as well as the turbo seal? Thanks.
