Vacuum
Trampisjr
50
Mar 12, 2006
Grundy, Virginia
Can someone give me a diagram or tell me exactly how the vacum hoses hook up?
I turboed my lil 420a engine and the vacume is a pure mess and I have no idea the way it was or use to be since I droped the new moter in.
Changed your thread title.
*Vacuum.
Can't help with the tech, however.
Just eliminate the vacuum lines. Heres what you need. A vacuum line from the fpr to the intake mani, from the brake booster to the intake mani, from the intake mani to the blow off valve, from the valve cover to the intake mani unless you have a catch can, from the turbo to the boost controller to the wastegate. everything else block off.
  • Wanted 6 bolt NT water pipe
    • chrisman287
