Upgrading Turbo, Mani & 02 Housing...
birdii
135
Sep 7, 2005
ON, ON, Canada
Ill be buying JMF tubular 02 Housing Internal Dump, EvoIII manifold & EvoIIIbig16g soon. Which kind of bolts, screws, washers, gaskets, or any other parts do i need while upgrading all three parts? I want to buy all the parts before taking it apart.
thanks!
97GST
Don't forget the head to manifold gasket, wherever you are getting the manifold should have it if it does not come with it.
I would recommend a good set of SS studs for the manifold as well. SSstuds makes the set I have. Will not end up backing out of the block, and they are a tuners supporting vender also.
I would recommend also checking out Forced Performance Turbochargers: FP 16G Install Kit for 2G DSM
16g install kit for a 2g that would make things a whole lot easier since it includes almost everything you are asking for in one kit. Also a great vendor.
Thanks for the replies :) ... Heres a list of parts im getting is there anything else im missing?
thank you
1 MR323654 4-LAYER EXH MANIFOLD GSKT
1 7CM 7CM TURBO GSKT.
1 EVO-O2GSKT Evo 02 Housing Gasket
1 VIB 1457 Vibrant 2.5" exhaust gasket
4 MR187699 BOLT, T/C
8 MR187848 WASHER, T/C
1 MD050074 02 Hsg. to Turbine Stud
4 MD132933 Washer
1 MD132930 NUT,
3 MD062961 BOLT,
2 MF660064 GASKET, TURBO OIL
2 MR258477 GASKET, T/C OIL RETURN
4 MF660065 GASKET, TURBO WATER
2 MF660031 GASKET, T/C
1 PUN J-Pipe Punishment Racing Aluminum J-Pipe
That looks good! Do you already have the exhaust manifold hardware I'm assuming? If not, then that is what you are missing. :)
