unknown problem i dont what it could be need help please
91gsdohc
1,099
Jan 25, 2010
around, Connecticut
it started to me yesterday i was driving and my rpms would drop to 0 then stall i would have to keep hitting the gas to have the car start i dont know if this help but the more info the better the other day there was this big rain storm and i dont know if my air filter sucked up water or not so i came here to ask for some help i drive a 91 dohc 2.0l gs n/t give me some ideas
did water get into your mas? i would think that might be your problem
the only things i got done i removed the airbox and advanced the timing but like i was driving just drop to 0rpms and i could sit there for ever tryin to crank it it would crank id hit the gas it worked yesterday but 2day i couldnt get it to go again i would get it to start i would keep hittin the gas so the rpms stay up b4 i put it into drive but it would just die idk whats worng i felt the filter and it seemed dry i just need help on wht it could be and what i need to replace
and idk if water got in the mas
how would i know if its the fuel pump or ecu
if your filter was dry i would think the mas did not get wet. test fuel pressure and inspect your ecu for leaking caps
how would i test the fuel pressure and wheres the ecu and how do i look for leaking caps
i cant check the fuel pressure i cant get the car started
the plugs and wires are brand new there is a missfire but that shouldnt be the problem is there any possablity is has anything to do with a bad tranny?
im bout to put in a new bat see what happens from there because now i cant get it started if theres any more ideas that i can check without starting the car let me know im bout to check for leaking caps
and another thing i just remembered was that when i was trying to start the car yesterday i heard something like a backfire but im not sure if thats what it was because the car didnt start it happned twice
just got back from the shop and they told me ignition module & camshaft postion sensor
