UICP/LICP & turbo swap
KPEclipse
335
Dec 14, 2003
South Jersey, New Jersey
I plan on getting my FMIC installed right away when it comes in because the sidemount is COMPLETELY heatsoaked. It's too hot outside and you all know how minute the sidemount is so im going to replace it right away. The dillemma that I have is that I am building a new turbo kit right now...and I already have my 14b with most of the supporting mods, I only need a few more things. My question is...when I switch from the t25 on the FMIC to the 14b to the FMIC...to get the pipes to still fit i know that I need a Jpipe. But will the LICP's still fit or what...like will I need to change the LICP's too or...?
depending on what FMIC you have it will all be different. For example, If its a side to side you can leave the UICP alone between turbos but you will have to change the LICP. If its a same side, then only minor changes will have to be made. Goodluck.
KPEclipse said:
crap...its a side to side...i think im just going to try to wait until i get my 14b put on to do all of it at once...thanks...
No problem, and I have found that the DeJon tool Jpipe works GREAT. Thats what Im running and piping was a sinche. You do have the option of cutting the elbow on your t-25 off, but honistly I would just wait it out.
  • For sale Evo 8 steering wheel with dsm adapter welded on.
    Evo 8 wheel with welded adapter for dsm
    • 98TalonPandaTSI
