Twin turbo setup... different psi from turbos possible?
peachpuff
Jun 16, 2010
ontario, ON, Canada
What would happen in a twin turbo setup if the large turbo is pushing 30psi and the small one 15psi. Would the airflow from the large turbo basically go back through the y-pipe that connects the two and choke the small turbo due to there being less pressure coming from the small turbo?
A friend is about to attempt to run a gt35r up front and a 16g mounted in the back but the varying pressure he plans to run from both turbos didn't sound right to me.
try working on an mr2. almost equally as crammed, and you gotta bend over pretty far to reach stuff. it doesn't hurt until you stand back to straight up.
