Turbo Timer Harness
Squirrel8811
188
Dec 5, 2008
Springfield, Missouri
When I bought my car it came with a turbo timer that wasnt hooked up properly. It came on but did absolutely nothing. Come to find out this guy cut a section of wire out of the tt. I fixed it and the car will now idle down and shut off like it is suppose to. Only one problem. I need to leave the key in accessory for it to work. If I take the key out it shuts off. I took the harness out and there is a red, green, and white wire that are not hooked up. From photos ive found these came with crimp connectors. From the looks of it they previous owner cut the crimps off of the red and white wires leaving the green. I hooked up the parking break wire and it works fine. You can see the white wire in the second pic going into the black sleeve but not coming out the other side. Im at a lose and dont know whats up. I thought this harness made it pretty much plug and play and its still the way it was brand new -2 crimp connectors.
anyone?
