Turbo Timer Harness
InjenTalon96
242
Oct 12, 2003
Plainville, Connecticut
ok guys i got my turbo timer harness in today, there is a plug that comes off my turbo timer with 3 wires that are green blue and red, that plug into the harness. now there is another set of three wires that are white, purple and orange that also come off the turbo timer. now off the harness there is 3 wires that are green, red, and white. i dont know how to color match them, i was wondering if i could have some help??!!!
uhhhh..... what kind of TT is it, that info would probably help.
if you are talking about the other end of the harness, you pull the ignition harness that is under the driver side of the dash, the "harness" is supposed to plug in between the ignition harness is now.
crappy pic ahead
current ignition harness. --><--
ignition harness with TT harness --><---><--
those other wires probably are supposed to go to the ecu. they should tap into the rpm signal wire something else and the ebrake
http://www.sp-power.com/catalog/images/GREDDY TURBO TIMER HARNESS.jpg
the harness looks like that.....the two big plugs i know where they go, and also the smaller plug i know where it goes because it goes into my turbo timer, notice the 3 wires that come out from behind it, green and red and also a white one that cant be seen, where do they go???? there are 3 more wires that come off my turbo timer that are white, purple and orange, so i dont know how to match them up, and if i were to match them up and they are wrong could i damage anything????
