turbo "break in"?
Texas gst
225
Oct 17, 2010
Lubbock, Texas
Do you have to "break in a turbo"? My T25 is going out (seals), so I should be getting my new one today. It is a used 16g and being that it's used, I can't afford a new one or even another used one. I didn't know if there was a break in procedure of any kind that needed to be done.
You just need to prime the oil system before actually starting the car with a new turbo.
It might be good to drive it around for a hundred miles or so w/o going into boost and beating on it. It never hurts to break things in before you start putting them to use. Generally though, a turbo will work it or it wont work. As long as it is primed, you will be fine.
