Tuning Help in the I.E.
mattp_65
Supporting Member
528
187
Aug 16, 2004
Granite Falls, Washington
Hello tuners,
I am sorry if I posted in the wrong section, but I really need help. I need help tuning my car before the track day at California Speed this Saturday. I tried searching thru threads and doing the tech articles, but I need some hands on experience.
If anybody Can help me in Moreno Valley, Riverside or Ontario area to help me tune with SAFC I would really appreciate it.
I am really confused on using SAFC, I can't wait until DSMlink V3 comes out. V3 is what I am waiting on but for now SAFC.
I have basics of SAFC, e.g. LO-settings... Everything is setup just need WOT tuning that is it. Also check Profile.
I get out of work at 3:30pm in ontario and get home in Moreno Valley around 4-4:30pm.
Thanks in advance. :thumb:
If you have the money, you can contact Tuning Technologies and they may be able to fit you in for a tuning session. They are in Colton, off the 10 freeway. As for Alfred.
Yes I would but they are always booked on their dyno and also I want to learn how to use the SAFC so I can install in it in my brothers 300zx and be able to teach him how to use it. After I get the V3 from dsmlink. Any help is appreciated thanks.
What are you logging with and can you post a log?
I did do a couple of logs with the pocketlogger and SAFC a couple of days ago, but (dumba** me) I forgot to log RPM, so I am going to do a couple of logs tonight and I will post them up.
The logs I did my timing didnt increase as much as I expected, and I think I am still running kind of rich. My wideband reads 12:1 at WOT @ 5500-7000 rpms. Should I lean it out more? I also logged my o2 (narrow band) on my pocketlogger and they were .94-.96 all thru out the run. At 3000-4500 rpms wideband was reading 10:1 which is really rich so I know I have to lean out there more, but my afc readings are about -40 at 6000-7000 rpms. Should I decrease my FPR? It is set at 43psi.
I also double checked for boost leaks and found a couple of TB leaks but fixed now. New spark plugs. I am boosting around 21psi. Boost stays at 21 psi and does not drop down until I lift off the gas pedal.
I hope this helps some people to figure out If i am doing it right.
Thanks
Hello again,
Here are my logs for night. And more disappointing runs. Timing is very low and and running about 11.8 A/F Ratio. Can anyone help me out? I got one more night to get my car street tune as much as possible before Saturday. Thanks for the help in advanced.
Edit: my hi-settings are around -33 thru -38 across the board.
  • For sale 4G63 6-BOLT OIL FILTER HOUSING
    Off a 91 awd 1G, buyer covers shipping / fee
    • The_Partout_Spot
  • For sale 1g Hatch cover
    Grey hatch cover
    • Anthony Hornback
  • For sale 1g Bumper lights
    Full set and an extra driver side.
    • Anthony Hornback
  • For sale 1g Torque Solutions Manual Front Motor Mount
    1G AWD Torque Solutions Manual Front Motor Mount
    • Anthony Hornback
  • Wanted 1g Headliner
    Looking for a 1G headliner with sunroof.
    • Anthony Hornback
