fuzzystsi
- 0
- Jun 19, 2012
des moines,
Iowa
I have a 91 tsi awd with a 90 jdm 6bolt i bought for dirt cheap because the motor was blowin its bored 20 over 8:5:1 2g pistons balance shaft elim i plan on using a 2g maf i have a tubular mani and will have full 3" exhaust i will be using an eprom ecu and have a chip burnt for it i have a big 16g turbo and will run a 190 wally it will be a daily driver that i want as reliable as possible so i will be running 20psi max normally and then maybe 25 if i take it to the track once in a great wile my main question is will 560 evos be big enough or should i get 650s i will not be running dsm link or anything like that i wanna keep the tuning as simple as possible because im not good at it nor do i have the desire to be or take my car somewhere everytime i need a tune thats why im having a chip made but i will be buying a wideband and data logger to watch knock and possibly and afc just for a little fine tune on the chip will this be an ok setup for what im wanting to do or does someone have any other advice i forgot to mention i have a full front mount and 2.5 hard piping and will also have an aftermarket intake pipe thanks for the help in advance it is very much appreciated
