transistor and cas
1995 brian
233
Dec 16, 2011
Leadville, Colorado
does any one know how to test the ignition transistor for a 4g63t engine. the reason i ask is because i have no spark in two cylinders and my coil tested out good so just trying to narrow down the possibilities. also same question for the cas.
:dsm:
How did you get to the cas? And no i do not have a CEL. Im missing spark in cylinders 2 and 3 (two middle ones) and my engine is cranking but it pauses. Did that with a fully charged battery so dont think thats the problem also tested the coil and it came out within specs. Any ideas.
:dsm:
I replaced a ton of things trying to fix this but the thing that did it was the cas. It only took me like 1-2 hours.
The cas is located under the cam on the back side (the one farthest from the radiator). The bolts on it just happen to hit the cam sprocket if you were to try to take it out as it sits (how convenient). Lol sorry about the rant.
So what I did:
Supported the motor -put a piece of wood on a jack and jacked it up a little to take pressure off the mount
Undid the drivers side mount
Took all belts off
Take timing cover off
Relieve pressure from the timing belt
Take timing belt off
Took the back side sprocket off
Replace cas
Retime and reassemble
Do you know if theres a way of testing it before i have to di all that?
At the top of the image you will see the diagram of the ecu with every pin numbered out. Next is the directions on how to check the voltage to make sure they are functioning correctly.
It says while cranking the cas (pin 88) should read .4-3v and while idle should be .5-2v.
After that test i would suggest checking the crank position sensor (pin 89) at cranking should read .4-4v and idle should be 1.5-2.5v.
