tranny swap. help ?
ldrgst
Jan 9, 2008
...., Massachusetts
are these all the parts i will need:
Shifter Assembly Shifter Boot Shifter Cables
Cable Hold downs and Firewall Gasket Brake and Clutch Pedal assembly Clutch Master
Clutch Fluid Line Clutch Assembly Flywheel
Flywheel to Crankshaft bolts Manual Transmission .Clutch Slave
and what do i do about the ecu ?!
thanks.
