Top radiator hose bloated
Josejoe
Mar 18, 2013
Madisonville, Texas
I do have a tiny bit of vapor coming from exaust but I know the head gasket isn't bad. I've ran a combustion leak test, a cooling system pressure test and a compression test and the car was good with all of them. It's not over heating but the upper hose gets extremely hard. I recently changed the thermostat. The radiator cap is ".9" any ideas of whats going on
It says .9 on top. And when I did the pressure test it was at a normal level on the gauge. I spoke to a local mechanic and he said if the gauge went into the red zone that then I had problems. And I will check the lower one as soon as I get home
On top of the cap it says .9 which is thirteen psi which is where it was at when I ran the pressure test
Compression tests time.
Or just go rent the tool that checks your cooling system for combustion gasses.
