Top end swap
psi4power
50
Dec 22, 2002
swaping a 97 turbo head,manifold,throttle body with 94 n/t same as other... my question being what would be the best working combo of these 2 to include cams, cam sensor also i already to know to switch the tb elbows
Your cam sensor will already work, you need a 1G water pipe and water neck as well... Use the Turbo 1G Exhaust cam and the 2G intake cam. I just did this swap last weekend but used a turbo head instead of a non-turbo.
i dont have any 1g turbo cams, its a n/t, also any need to knows on the vacuum hookup on the tb and anywhere else that might change
