Too much car for me? 500hp 99 GSX
RepeatDSM'r
Aug 26, 2012
Vancouver, BC, Canada
Hi all,
I'm considering buying a another DSM. I had a 97 Talon TSI 10 years ago and I would like to get another one for fun to drive on weekend and the odd track day. I've come across a heavily modified 500hp 99 GSX. It's running at 32 PSI. The build quality is great but I'm wondering if it's too much car for me. I would prefer to run at a lower boost for 350-400 HP. It's currently tuned for 500hp.
I like this one because of the quality of the work. Most of the mods I would have to do are only aesthetic.
The car details are below. This would be a second car.
I'm wondering if I should get this car and tone it down or wait until the right (less modded) car comes along. Please comment on any implications of detuning (smaller turbo? New manifold?) vs leaving as is.
Any input is appreciated.
Engine:
• 2.3L stroker Fully forged internals
• Wiseco pistons
• Eagle forged rods
• Eagle forged crank
• Stainless steel valves with bronze valve guides
• 3mm upgraded lifters
• A1 Technologies head studs
• Felpro-R 5 layer metal head gasket
• Comp Cams
• 880cc Precision injectors
• BC adjustable cam gears
• HLA oil pressure regulator
• Magnus intake manifold
• 1G throttle body
• ETS intercooler
• T3 housing header
• Precision 62mm Turbo
• 44 Tial External wastegate
• Turbosmart boost controller
• 3" Exhaust from the turbo back
• Velocity stack stainless intake
• Cooling mist Methanol injection kit
• Dynatec ignition box
• $1000's Spend on Dyno tuning at RG Racing with ECU link V3. Made 498HP to the wheels*** with a safe conservative tune. Very streetable.
Transmission:
• Fully rebuilt 5-speed manual
• Upgraded Evo gears
• ACT 6-puck sprung ceramic Clutch
• ACT Lightweight Flywheel
• B&M short throw Shifter
• Brass shifter bushings
• 4-Spider center differential
Chassis:
• 18" Niche chrome wheels with new 225/40r18 tires
• Suspension techniques Lowering springs
• Urethane Bushings
• 13" Front slotted Cobra brake conversion kit
• Powerslot rear rotors with hawk pads
• Stainless braded brake lines front and rear
Electronics:
• Alpine Mp3/CD/iPod head unit
• Alpine 4-channel Amp
• MB Quart Component Speakers
• 2-way pager alarm with keyless entry
****Less than 3,000miles on engine, transmission, and all aftermarket parts****
Thanks for all your replies. I'm looking forward to being back in the club!
How will running it at 20 PSI vs 32 PSI when it's tuned for 32 impact the experience? Will it adversely affect the car?
Youll need to retune the car but that wont be a problem since it has dsmlink v3... if i bought that car and i were you, i would take it to a professional tuner to get it turned down though because it would be a disaster to blow that motor up! As for being to much car for you, it all comes down to the person driving it.. are you a responsible driver? Do you know what to do with 500 hp? As long as your responsible in it and not doing anything stupid and you can drive the car shouldnt give you any trouble, but dont screw around in that 500hp can get out of hand VERY quickly :thumb:
Thanks Boosted!
Any idea what it will cost to retune/detune it?
Thanks,
Hopefully repeating soon!
Rule of thumb...
Respect the vehicle dont be afraid of it..
Big difference... If it was me i'd get it.. tune it down to 20 - 24 psi and enjoy the car knowing later on in life if you feel the need to tune it up you have that option :)
