2G Tokico Illumina question
DsM KiD4
223
Dec 25, 2006
salinas, California
I have the tokico illumina suspension kit from extreme psi. When i put the spring over the shaft, its angled upward. Meaning the shaft isnt in the middle of the spring, its closer to oneLOL side. Is this normal? On my stock shock & spring its in the middle, i dont know what to do, thanks! 2g awd
Another thing to look out for is the spring seat at the bottom of the shock has an angle to it and a step. So you need to rotate the spring around so the end of the spring abuts against the step.
Mine was the same way. I have the Tokico Illumina Setup for the AWD.
Is it ok if its not seated next to the step? Its about an inch away.
Spin the spring until its seated. You might have to loosen the bolt on the top of the strut.
