mikejm7
- 0
- Jul 10, 2005
Toronto,
I was just wondering, since i have a 15lb spring configuration in the wastegate will it automatically stay at 15psi boost without any vacuum lines attached to it?
If there has to be a vacuum line attached, which vacuum port on the wastegate should i attatch it to, upper or lower?
Once i get a MBC, can i adjust the boost below 15psi or just increase it?
Thanks, Mike.
Thanks, Mike.
