The Official "What's this DSM worth?" Thread
Automatic , all original leather infinity, unmodified. 43000 miles... Did I get robbed? Car runs perfect..
I'd say you got screwed. I have seen several 96-99 Turbo DSMs in the St Louis / Southern IL area in great running condition with mods going for less than $5000
I don't know about that, 43000 on an awd is pretty low, hell that thing could be on original rubber yet. If it is very well kept I think its a pretty good deal, I've seen clean awd cars go for upwards of 8000 with more miles on them.
i bought a 1991 gsx 5 speed for a grand with a blown motor the motor has 550cc greddy injectors 16 g turbo new fuel pump fuel pressure regulator and gauge Catback Exhaust System and kby struts. the guy also sold me a motor for 200 bucks with new belts .the car does need some tlc it has some bad rust spots arond both fenders and the rocker panels.
Doesn't seem like a bad deal. If you just add up the aftermarket parts on the car, it's worth more than you paid for the whole car - so I think you made out pretty good!
What kind of fuel pump oem?
I cant tell the rust in the avatar show so pics.
im not sure if its a oem fuel pump and the motor in it right now has bent valves from a broken timeing belt
You lucky SOB!! You dont need to replace the motor. timing belt and valves. Or if you want to buy a used head. ( I have one laying around with good valves in it.)
Good deal another DSM'er
My step-dad wants to strike a deal with me. I sell my 93 AWD and my Jeep, pay off the loan to my parents, and he will GIVE me 5k. I looked for awhile at cars around me and a days drive away. Found this one. Looks like it has the supporting mods for all the power adders.
1993 Talon TSi AWD
Here is a run down of mods.. Motor Has just over 5K miles since rebuild.
Big 16g turbo
JM fabrications FIAV(fast idle air valve) block-off plate (necessary for proper idle after removal of coolant hoses to throttlebody for cooler charge air)
AEM uego wideband/controller(bung welded directly to downpipe)
Autometer boost guage
HKS turbo timer
Apexi SAFC2
GM 3" maf and translator ver2.0
sleeve and spring stle coil overs
front and rear cross drilled/slotted rotors
factory 4bolt rear end w/factory 75w-90 and LSD addititive
Redline heavyweight shockproof gear lube in trans and ctr diff(t-case)
Royal Purple oil in engine since break in
front and rear camber-kit
TurboXS dual stage boost controller
2g pistons/ 1g big rods
balance shaft removed
Evo 8 mls headgasket
ARP main, head and rodbolts, Crower springs/retainers
DKS 272 cams
5 angle valve grind
shearer fab I. manifold
2g exhaust manifold (ported)
SFP 02 housing
N1 turboback exhaust
Greddy timing-belt
FIC 750cc injectors
XS power Fuel pressure regulator
warlboro 255 pump
Keydiver eprom ECU w/stutterbox (many other features too)
FMIC
Tial BOV
$4000
Hey guys im looking at this dsm for sale and i have been talking to the guy for awhile now. He wants $4400 for it and its a 95 eclipse. It has the 420 engine with a turbo. The engine has been fully built with eagle rods, je pistons, ect. It is set to boost at 18psi right now. The interior of the car is super clean. Is there any downfalls to buying a boosted 420. I also have a 95 tsi awd talon that im working on. I was going to make the eclipse my daily driver while i finish up my talon. Can someone give me some feedback about this. Thanks
Supremedsm :D
well he does the work himself and he has receipts for all the parts. he drove the car around how it is for a year until the transmission went out. and hes about to replace that for me with a brand new one. here some pictures of the car.
MySpace.com - DSM Head Turner!!! New Eclipse
i think its a pretty good deal hes going to let me make payments on it for $400 a month for 11 months since im in the military and we going to make a legal contract and sign it.
I don't recommend doing that. And you should never let the fact someone is willing to let you make payments be a part of your decision on buying a car. Bad idea. If you just want a DD while building up your other car then I don't suggest going through all that. I'd seriously look at something a little cheaper, in your budget, and not something ready to "show off" in.
What is wrong with making payments on a car? i have never had any problems with it in the past! and im not to sure when my talon will be done cause there is alot that i want to do to it. so it could be awhile. and of course i would love to show it off =)... but who wouldnt? i was actually thinking of buying it for me and then building up my tsi for my brother so that when he gets his license then i can give the car to him as a gift.
