For Sale The HOLY SHIT thats a lot of parts list!
dacowgod
Supporting Vendor
451
280
Feb 3, 2006
Morgantown, West Virginia
Its been a minute since I posted an ad ... but I have been hard at work... I have a TON of new inventory here read this list 3 times -- PM me or txt if you need photos or more info.. 304-813-2405
Located in Morgantown WV
1995-96 TRE Trans w/ Kaaz Center diff - (Dont forget you can use a 2g trans in a 1g easily but not the other way around) - $2400
(Dont forget you can use a 2g trans in a 1g easily but not the other way around) 1995-96 Extreme Motorsports stage 2 trans with 4 spider diff - $2000
2g DSS 900HP Stage 5 Rear Axles and Spindles - $1500
JAM 1g head - EVO 9 springs/retainers - Farrera Valves - 0 miles - $600
Tein Street flex Coilover system 2g DSM - $750
2g ECMLink V3 Full w/ ECU and cable - $575 Add sd package/SD cable for $125 more
Cleaned and Flow tested PTE 1000s (With flow sheet) - $295
FIC 1650 HI-Z injectors(These are the largest HI-Z injectors compatible with Oxygenated fuels like Q16) - $525
FIC Silver Fuel rail w/ spacers -6 fittings - $120
Magnus Launch control device - $200
AEM Meth injection kit with 5 gallon tank/progressive - $350
s90 Throttle body - $175
Magnus 1g Race Intake manifold - $425
AFCO Scirroco style Dual pass radiator - $300
AFCO fans w/ shroud for the above radiator - $200
EVO 8 Brakes/Rotors/Pads with DSM brackets - $775
Comp 6262 Triple ball bearing turbo T3 in 3" Vband out - $700
Alt relocation - $125
Moroso 6 bolt oil pan - $425
Magnus fuel rail -10 fittings - $120
JAM Built 6 block short block - Arias pistons - Eagle Rods- ACL Bearings - MHI Pump - Balance shaft delete - $2000
JAM 1g head, 1mm OS Valves, Supertech Dual Valve springs/retainers - $725
HKS 272s - $375
AEM Cam gears - $135
AEM Wideband - $125
AEM Boost Gauge - $120
AEM Oil pressure gauge - $120
AEM Water temp gauge - $120
AEM Voltmeter - $95
AEM EGT - $120
2g Carbon 2 gauge bezel (To replace center vents) - $75
QM Twin Disc clutch - $750
JMFab T3 Top mount manifold - $850
Purple "Nology" hot wires spark plug wires - $75
Full blown 2g dual fuel pump hanger - 10 feed -8 Return (Anodized purple) - 350
Purple Magnafuel AFPR w/ -10 in -8 out - $150
Dual External Walbro 255's with bracket - $125
NRG Front Seats w/ Bride Brackets - $700
JMFab COP plate with 300m coils and splitfire ignition system - $450
Cleaned and flowtested ID 725 Hi-Z Injectors - $350
Cleaned and flowtested ID 1000's - $425
Cleaned and flowtested FIC ASNU 1050cc injectors - $400
Red Tial BOV - $180
2g Skunk2 coilovers w/ Tokiko Blue struts - $450
Brand new 2g/evo Oliver Billet "Ultralight" Rods - $725
Used DNP Style exhaust manifold (DSM Flanged) - $50
Chinese 16g in good shape - $75
2g black box ECU - $75
EVO 8 ECU - $225
BBK 62mm DSM Throttle body - $150
Accufab 75mm Throttle body (Mustang flange) - $150
3g Lifters - $65
Genuine Greddy type "RS" Bov - $75
ARP 6 bolt head studs - $50
ARP 7 bolt head studs - $65
Walbro 255 pump (2g) - $40
BNIB Walbro 450 - $100
Delta 272 Cams with shims - $300
63mm Non turbo Throttle body - $125
Competition Stage 3 clutch (Very low miles) $275
4 bolt manual rear end w/ axles and cups - $400
red AEM Fuel rail w/ spacers - $100
2g GST 5 speed Transmission - no grinds - $350
2g GST Auto Transmission - shifts as expected - $400
2g ECMLink SD harness - $50
Brand new GM IAT w/ bung and pigtail - $25
Used DNP Style(No name) DSM Flanged tubular exhaust manifold - $50
JPipes Jpipes Jpipes!- $25
Complete 2g AWD Auto swap in good shape(Includes everything to make your manual AWD an auto AWD) - $1250
Good pull stock 6 bolt head - $225
Good pull stock 7 bolt head - $225
Brand new 2g/EVO Oliver Billet Ultralight rods - $750
Billet Unorthodox Racing Aluminum crank pulley - $40
Weldon Inline fuel filter -6an $75
Good stock 95-96 2g AWD 5 speed transmission 110K miles - $750
ACT 2600 pressure plate - $125
ACT 2100 Pressure plate - $125
good low mileage ACT 2600 clutch kit - $275
VERY (Like NEW) low mileage Competiton Clutch kit Stage 3 w/ 8 puck disc and 6 bolt AWD Flywheel - $450
Act Streetlite 7bolt fwd flywheel - $100
Braille - Small battery tie down/tray - $85
Good 2g MAF - $25
Green powdercoated Brembo brake set w/ rotors and pads - $675
os giken DSM twin disc clutch - worked well but will need a rebuild - $450
Revised 3g Lifters - $65
2g pair LSD rear axles $200
2g LSD Auto Rear end - $225
2g LSD Manual Rear Diff - $225
2g Non LSD Auto Rear end - $200
2g 91-96 Auto Tcase - $150
22 spline manual tcase - $150
23 spline manual tcase - $150
Good manual half shafts w/ carrier - $75
Cleaned and flowtested Stock 450 DSM injectors(Blue tops and black tops) - $75 per set
Cleaned and Flowtested Rc 550 injectors - $100
Cleaned and flowtested EVO 550s - $100
Cleaned and Flowtested FIC 950cc injectors - $255
2g non abs prop valve w/ hard lines - $80
1g non abs prop valve with hard lines - $80
Recently rebuilt to stock 1g head - $300
Recently rebuilt 1g head - BC Springs/retainers - Fresh deck - $450
Good Engine harnesses (1g/2g Auto and 5 speed available) - $150
EVO 8 Steering wheel - $250
Red fuel lab filter to rail kit -6an - $85
2g prothane motor mounts (Manual) - $75 (includes the mounts and inserts)
FP Intake recirc w/ couplers - $110
Uncracked valve covers - $75
2g Tokico blue suspension w/ tokiko red springs - $325
PTE 60-1 bolt on Turbo - $525
cleaned and tested RC 1200cc injectors - $250
Tial f38mm wastegate - $125
BC 272s - $325
EVO LIST-
Cleaned and flowtested PTE 1000cc injectors - $255
Cleaned and flowtested PTE 550s - $125
Cleaned and flowtested Very low mileage ID 1000s - $425
EVO RS Doors complete set with manual windows (complete set) - $600
Front Brembo calipers (Could use refinished but work perfectly) - $400
GSC S2 EVO 9 Mivec cams - $475
EVO 9 Head core - $750
EVO 8 Valve cover - Tapped with 2 -10 AN Fittings (has a few chips in VC but doesnt leak and not cracked - $250
Good used Walbro 255 - $40
EVO 8 Fuel sender assembly - $125
Apex Silver driver side fender - $225
Good ACD Pump - $450
Healthy Complete EVO 8 long block 92000 Miles - $2750
GOOD ACD Tcase - $1200
AEM Fuel rail - $125
AMS Fuel Rail - $125
Cusco 23.5mm rear swaybar (painted purple - $250
Bushwacker stage 2 5 Speed Transmission(Was torn down locally and inspected and refreshed has 0 miles since) - $2250
5 speed conversion parts - $250
EVO 8 ECU - $225
EVO 8 Steering wheel in 7/10 shape w/ airbag - $225
EVO 8 Wiring harness - $175
Low mileage LSD Rear Diff - $575
Rear axles - $250/pair
Front axles - $100 each
EVO 8 SSL Seats w/ door cards and arm rest (There is a very small tear in passenger front seat) - $875
SSL Door cards - $200
SSL Arm Center console - $100
slightly used Gates racing kevlar belt - $50
EVO 8 Blue recaros - (Driver seat has a tear in the left side bottom and is worn - $350
EVO 8 Dash board - $150
EVO 8 dash cluster - $125
Good used alternator - $65
Good used power steering pump - $100
EVO 8 power steering rack - $150
EVO 8 Non sunroof roof skin/frame/headliner - $250
Damaged Fortune auto coilovers (only 3) - $200
ETS Intake kit - $135
5 speed base with cables - $200
Apexi N1 Coilovers - $800
ARP Head studs - $65
ARP L19 head studs - $200
No-Tick Lifters - $65
Damaged set of RPF1 - 17x9.5" - All 4 wheels are damaged see photos(2 wheels are cracked - 2 wheels are severaly curbed, 2 tires are sliced) - $250
Have a complete EVO 8 parts car here with many additional parts that arent listed.
There is SO MUCH more here not listed - CALL OR TXT if you need something - 304-813-2405T
Located in Morgantown WV - - MUCH more not listed PLEASE CALL OR TXT
304-813-2405
