TESTING A 95-96 Cam Angle Sensor??
jjbrasil
143
Apr 1, 2003
Northville, Michigan
im pretty sure my cas is messed up and i would like to know if thier is a way of checking the cas on my 95 talon without having to taking off the cam sprocket and finding out the cas is ok, and having done all of that work for nothing...any help would be appreciated :D
What makes you think it's bad? If you pickup a Chilton, theres a way to check it with a voltemeter, but you may need a special tool from mitsu. The car should start (roughly) with the cam sensor disconnected, but keep the crank sensor installed.
my_gst95
tbehling said:
willl the car get spark without the cam position sensor connected?
Generally not. From reading the other post, I would say it still sounds like a coilpack problem. Not many things cause two cylinders to go bad. If you wanted to test it, you could always crank it over by hand and listen for a hum/click. If you hear any of your injectors firing or if you see any sparks, then you know your cas is good. Maybe half the fins on the back of your intake cam fell off?
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
