T3 Help
noyorol_1
114
Sep 12, 2003
Williamsburg,
I just got a adapter plate made for it and I got a t3 garret turbo.What do I need to do to get the oil line waterlines and the down pipe to fit.Alos do I need the t3 exhaust housing or could I use the stock 2g housing.Any insight info or hep would be great.Thanks
on t3/t4 turbos you will need a custom o2 housing made, or buy one from several different places, such as DSmotorsport, slowboyracine, AGP turbo, ect.
As far as the water lines go, most t3/t4 setups do not use water lines, so you will have to block them off. Now if you are using a t3 that is water cooled as well oil cooled then you will need to get the bango lines for that turbo. Garret might have the water lines, not sure though. What kind of turbo is it? there are like a million types of t3 t3/to4e t3/t4 t3/to4s and the list goes on and on.
As far as the oil line you can order a stainless braided line from any of those companys I listed above.
Hope this helps some.
I just read and printed out your tech articles.It was really helpful.All i know right now is that its a t3 garret turbo.but i will post pics of it.But I hope you dont mind if I pm you for helpo and questions about it.The set up.I will be putting the set up on in mid to late august.
