switching from coilovers to springs
talontedtsi1995
140
Sep 14, 2005
reading, Pennsylvania
My current set-up is come ebay coil overs with kyb adj. shocks, after having this set-up I realized how bad it rides no matter what yet like the low look. What springs would you recommend in order to achive a decent ride ride yet not as bad of a ride as I currently have with cheap coil overs? Thanks
I recommend you get a real suspension setup. Koni Sports + GC ftw!
But if you must, look into Eibach Prokits for good street ride with a nice drop. If you want a bit more handling but less of a drop go with H&R Sport OE's.
He said he wanted a nice ride, thas something you wont get from a GC setup. either go with a Koni yellows on a mild spring or go with a nice REAL coilover setup.
What kind of height are you looking for? What are your goals for the car?
For contrast, I much preferred the ride that a Koni+GC setup provided over my Illuminas + Prokits.
Anything will be better than what you are currently running though.
looking for something with a better ride than what i have. As long as it does not sit to high or ride as bad as it does now ill be happy, here is a picture of how it sits now.
does anyone out there how the sportlines or their car? if so how does it ride? i would it be an inmprovment over cheap coil overs? thanks, i am running 18s on the car and looking for something thats not to much higher.
  • Wanted 6 bolt NT water pipe
    • chrisman287
