suspension, cv boot, struts????? problem?
chris grunst
Aug 8, 2009
traverse city, Michigan
i have problem? when i push down on the front passenger side fender it make a squeaky noise when it gose up and down. I have 2 inch's of travel from the tire to the fender on the drivers side and 3 on the passenger side? idk someone help?
If it was a bad strut you'd be able to feel that side rock up and down when you hit a bump. That's likely what it is considering the difference in wheel clearance. As far as the CV joints. If they were in bad shape or poorly greased you would likely hear them make a popping or clicking noise, particularly during turns. It's easy to check if they need greasing by just looking or feeling. They should be pretty well filled.
