Surge?
garrek11
201
Apr 4, 2009
Spokane, Washington
ok this just recently happend i nodice when i was driving down the street i would here a click in my climate controll area then the check engine light would come on and the car would surge really bad all in a matter of about 6 sec then the check engine light will shut off and run fine for a while? WTF?
Sounds like the relay box under your glovebox is faulty.
Try pluging/swaping a friend's relay to test it.
Cheers !
Cheers !
That or your ECU is resetting causing your MPI relay to reset (the click your hearing). Do the other instrument lights come on too when this happens? My EPROM socket was coming loose in mine and would frequently cause the ECU to literally reset while driving down the road. When it did it would show all the instrument (coolant, abs, etc) lights as if you had just turned the key on getting ready to crank...all while going down the road at 70mph LOL.
nope none of those come on could it be ### my ac is still pluged in but i dont have the pulley installed and i tried to run it. ### if my ecu was to reset it self i would know ### my car runs a lot better when it does.
  • Wanted 6 bolt NT water pipe
    • chrisman287
