Sunroof Question
SPYD3R
82
Oct 25, 2005
Austin, Texas
When I bought my car, it came with an after market moonroof. Whenever I hit speeds upward of 80mph, you can hear it whistleing and air leaks thru, and when you push up on it, it makes more noise(duh). But is there a way to fix this?
How to I go about replacing weather strips and such? Cause mainly all of mine are bad.
Ever since I've had this car the sunroof has squeeled around 70mph or less depending on how fast the wind is blowing.
Is there some kind weather stripping that I can get or is this a normal thing?
My dad suggested using vaseline to seal it up, but that just sounds to messy and hick.
If the seals around the sunroof are good, then you may need to install some washers in the latch to make it close up better.
Also check the scres in the glass that hold the latch on and the screws going into the roof that hold it on. Mine were loose and my sunroof did the same thing. I just tightened them and it went away.
  • Wanted 6 bolt NT water pipe
    • chrisman287
