Sunroof cable question
AZDSM
80
5
Sep 1, 2006
Fort Hood, Texas
Had to replace one cable as it snapped in half and wouldn't allow the sunroof to retract fully. So I decided to replace the other side while I had the headliner and all that crap off.
Low and behold, I go and snap that little plastic piece that holds the end of the cable.
http://imageshack.com/a/img14/1200/t0wu.jpg
So 2 questions.
1. Do you think I can just use super glue to mend the 2 plastic pieces back together? I don't think it'll hold as the load bearing will always be on that little clip that broke off (bottom right of pic), so it'll eventually separate itself or should I just glue everything to itself OR should I just buy a new track?
2. What kind of grease is suggested for the new cable? This document ( http://web.archive.org/web/20060514...ix.com/users/manualcd/gift/dsm/2g_sunroof.pdf ) indicates the cable should be greased, but no indication as to what or how much.
Thanks.
Support glue is not what you want. To brittle. 5 min epoxy will do a much better job.
The grease for the cable can be almost anything, but don't use WD40. It evaporates and leaves a sticky film that will trap dirt I'm it
  • Wanted 6 bolt NT water pipe
    • chrisman287
