LastPANIC
- 0
- Mar 29, 2018
Madison,
Wisconsin
Hey guys, so iv been having a stutter for a while and i can't pin point whats causing it. For Example my log will show me at 4600 rpms then jump to 7000 then back to 4600 and i know i didn't go to 7000 rpms.. But this also causes me to see knock
Iv swapped out/ replaced the following:
coil pack
power transistor
plugs (bpr7es Gapped to .028)
plug wires (NGK 7mm)
Boost leak tested (held to 28 psi)
What I'm running:
Evo MAF
1250cc FIC injectors Low
340 aero pump (rewired)
AFPR (43psi)
14B (12psi)
any ideas would be awesome thanks
coil pack
power transistor
What I'm running:
Evo MAF
AFPR (43psi)
14B (12psi)
