Stutter at boost????
btracer
187
Oct 21, 2002
reading, Pennsylvania
just like the title says.. when ever i get on it good the car hits at about 3k and sorta dives in and out of power till i let off. need some help bad, mods are big 16g, 550's, evo VII ecu, 1g head, 264/272, etc. no safc and im wandering if im gettin some sort of fuel cut? holds boost at about 19psi. any help is greatly appreciated!
im pretty sure if i lower the boost and reset the ecu it'll be ok. i need to get an s-afc and tune the b!tch.... but any advice is greatly appreciated
Wait a minute, you don't have fuel control with 550cc's? Of course the car is going to stutter from being pig rich once it hits boost. :thumb:
the ecu was flashed and programmed for the injectors but i think runnin 19psi is a lil too much.... tomorrow im goin to replace the plugs, check wires, and do a pressue test. hopefully i can get her back on track
well i got some new plugs, im doin a boost leak test, and i ordered a AFCII last night... hopefully ill get her back on the road. thanks a lot guys, i let you know what fixes it
its actually lean, not rich cus the plugs are all white. i lowered the boost and im doin a boost leak test soon, got new plugs and wires comin plus an AFCII. let you guys know what happens
