90blacktsiawd
- 660
- 14
- Nov 8, 2004
Bethlehem,
Pennsylvania
So i just got my car back from getting a new head, tranny, cams and turbo on. I then put a new front mount on as well. I was having a problem with idling but eventually the ecu learned the new setup and its better now though not completely gone. I did a search but couldn't find any one with the exact same symptoms. My car won't get over 4k if I'm giving it some gas. The turbo starts to really spool at 3k and starts to pull harder up to 4k which seems to be were the car should be taking off. It's like i just hit my stutter box. A puff of smoke comes out, the exhaust pops and it just can't get through the rpms. It's definitely not fuel cut. I've experienced that before and this isn't it. If i very lightly push on the gas i can get up to about 5.5k but then it stutters to hesitate. If i free rev it in neutral i can hit 6k before it does the same thing. I'm not knocking when this happens, i have all boost leaks up to 23psi fixed, plugs and wires all look good and are only about a month old and messing with my translator doesn't do anything wether i richen it up or lean it out. Plugs are gapped at .28. Also my o2's seem to be fine when i get on the gas. around .90 - .92.
Now for the weird timing issue. When i got the car back the mechanic had the timing set at 20 BTDC! I fixed that and have it down to 5-6 BTDC now. When i ground out the ecu and lock the base timing in it holds steady but jumps to 10 BTDC and you can hear it in the motor when this happens.
I'm going to pull the ECU today to make sure it doesn't smell like fish but it's already had the caps replaced about 3 months ago. Please help on this one I'm totally stumped.
