stock pump how much boost
I wouldn't run too high unless you re-wire it...With a re-wired pump (cost=$15), I think you could get probably up to 15-18psi on the 14b but that is pushing it...Without re-wiring it, I wouldn't run after 14-15psi on the stock turbo, even less on an upgrade...The talon I am buying is running really low boost b.c it's on a 16g with 560cc injectors and an safc...If I decided to raise the boost to like a normal 15psi, I would run so lean it's not even funny...so don't push it, I would just invest $95 and get a 190lph and then run anything up to 20psi +/-
