stock mas. in blow through mode
srGS-t
51
Jul 12, 2005
Hueytown, Alabama
ok i just have one ? can u run a stock 2G mass in blow through mode.
BOV====MAS.====T body ???? I have a ECU+ so I can mess with ecu????
Just get the GM MAF from a junkyard if you're concerned with price. There's a list on here of all the cars you can pull it from. It's basiclly any newer GM vehicle made. and then buy the UICP off ebay with it already set up for a blow-through set-up. a pipe is a pipe whether is says greddy on it or not.
im not really wanting to Vent the BOV i just need to run the filter on the Turbo....so i wont have a intake pipe.....thanks tho
Are you going to get a reducer for your airfilter to like 1" for the t-25? Also, Why in gods name would you want that filter right there, Let alone in the hot engine bay at all? Mine is down infront of my tire. Do you realize how hot the air actually is in your enginebay, That your filter is sucking into the motor?
No kidding. Sitting in traffic lately my intake air temps are around 145!! Even crusing I don't see better than 105-110. It's too hot here...
Don't put a filter directly on the turbo.
If you don't want to spend money on a Dejon pipe, get a 3" accord intake pipe from Walmart, some couplers, a 3" GM MAF from ebay and you are set. The ECU+ has a MAFT built in, so you don't need a seperate MAFT unit.
Don't forget the non-trivial cost of a MAF Translator.
